5 members (dt235sd, Gray_Ghost, Peggy M, moparguy, ShopRag), 140 guests, and 0 robots.
Topics128,163
Posts1,056,920
Members48,458
Problem 2.5* negative camber on the right front. Noticeable tilt to the wheel.
Left side 1.5* negative.
Built a I beam support under the axle. Used a 20 ton press bottle Jack and loop fixture around the king pin and I beam. Used the Jack to bend the axle back to spec.
[URL=http://s398.photobucket.com/user/showkey_bucket/media/image_zpssyngjvso.jpeg.html]negative camber pic[/url]
Picture of camber set a 30' positive after "adjustment"
[URL=http://s398.photobucket.com/user/showkey_bucket/media/image_zps8mfv5uyj.jpeg.html]positve camber after adjustment[/url]
Your links don't work for me...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
They do not work me either.
Bill Burmeister
Changed links to photobucket............
Pic #2 looks about right- - - -but I don't understand the "30' positive" description. Maybe that's "3 degrees"? That's going to create a little inside tread wear; +2 degrees would be better. What's the caster measurement?
30' is 30 minutes or .5* positive
Spec is 1.5* or 1* 30' positve camber +/- 1* as per my shop manual.
Caster is 1* as it sits. Prior someone added a caster shim. Going to leave it as is until I can drive and see how it handles.
Certainly not interested in + 2* or 3* camber.
