3 members (Hotrod Lincoln, 1955 1 Series, tricordati), 157 guests, and 5 robots.
Topics128,095
Posts1,056,480
Members48,444
#1155642 03/18/2016 8:33 PM
Hello:
It's getting time to replace my clutch. I haven't got it apart yet, so can't see what's in there. Catalogues show both a 10" and an 11 3/4" clutch for my truck. Anyone know which one is right? It's a 235 with 3 speed transmission.
Thanks!
Glen
Riding in the Passing Lane
Usually you need to pull it to get the right one. There are several options. You might get a good idea by removeing the bottom cover & measureing.
1972 Chevy c10 Cheyenne Super
My Parts Book says the 10" is standard duty and the 11" is heavy duty, there is no mention of 11-3/4".
The 1965/66 C10-30 have an 11-7/8" HD Clutch.
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks guys. I was hoping not to have to crawl under till it was time to do the tear down, but perhaps that isn't the case.
Perhaps what I thought was 11 3/4 is actually 11. It was also cheaper!
The bigger clutch won't hurt, it may be a little grabbier than the smaller one.
How do you use your truck, do you carry heavy loads or pull a trailer? If so get the 11".
If only light duty the 10" will be fine.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
You have to use the size that the flywheel is designed for.
Ah... So 235's had more than one flywheel clutch surface spec?
"Ah... So 235's had more than one flywheel clutch surface spec?"
Since 1941?
Any flywheel since then would fit any 235 (I think).
You might never know what year/engine your flywheel is out of. It could be from most 216s (maybe any 216, I think), any 235, or any 261.
That is why Wrenchbender early-on above suggested: "Usually you need to pull it to get the right one."
And later on: "You have to use the size that the flywheel is designed for."
This is what we all have to deal with - you know know what size you need until you know the actual size you have in your truck. Ain't life fun?
Sir Searchalot
Sir Searchalot
11" is what you want.
Thanks again guys. Yes, life is fun with these old trucks.
