1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | In the process of rehabing my guages and have taken them out. Is there any trick to getting the temp/oil/trottle/choke cables through the new rubber gromet? I suspect it is a matter of cutting into one side of it and shoving all the stuff back through..Thanks, Scott | | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | How ever you do it, it will probably be time for a new grommet when you are done.! | | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I had mine all wired up and wire and such through the fire wall with no seal and I ordered new seals and put them on last week, I took a box knife in one spot cut the seal, wrapped the seal, around the cable/wire harness and then took superglue and glue where i cut back together and pushed it into the firewall, worked good and easy | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've heard of people using superglue with success. Steele recommends Loctite 495 which I've used with great success. The down side to the 495 is once open it has a very short shelf life. Buy only the smallest size you need. It will not keep for long. Keeping it in the fridge may help it last longer. I bought the large bottle thinking I may need some later only to find it all dried out the next time I tried to use it which was only a few weeks later.
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Single grommet, split to install if just replacing the grommet. Multi hole grommet like the one the Choke, Throttle and Temp gauge run through/ I split into one hole, then split the web. You can pull the Choke and throttle out and feed back through...but that temp gauge? Not gonna happen. 3M makes a good weather strip adhesive in black. It works well. Just a bit on the cut ends and a little clean up. Stays flexible too.
Steve H
