1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Installing a new 12 volt fuel gauge on my 53 1/2 ton and once installed I noticed that due to a different needle indicator it sits up slightly higher than the original and the glass cannot fit flat properly. Anyone delt with this problem? Thanks, Scott | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | It should not hit the glass It might hit the bezel. Just push the bezel out a little to clear pic ...pic... | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Thanks, after I wrote this I went out and realized I had put the gasket and glass and bezel in the wrong order and fixed it. Scott | | |
