4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
#1155874 03/20/2016 4:19 PM
I have a 66 Suburban with the heavy duty rear spring package. I was told by a local who owned a Suburban, that it rides way too rough with the HD Springs. I picked up a set of standard springs from a 1/2 Ton pickup, with the intent of putting them in. It seems kind of strange to me that the HD springs have the center coils contacting. I have never driven the vehicle, so I have no idea of what the ride is like. Does anyone have any experience with the 2 types of springs, and which would work best? I do not plan to overload or tow with the vehicle. I have just one rear seat. The top picture is the HD spring, and the second picture is the standard spring.
Thanks for the help.
http://s1375.photobucket.com/user/rps2657/media/DSCN0903_zpsdiccuhvb.jpg.html
http://s1375.photobucket.com/user/rps2657/media/DSCN0904_zpssi2znres.jpg.html
Sir Searchalot
Sir Searchalot
The 1966 C10 came standard with two stage rear coil springs. Similar to your first picture. An optional higher load rating was available but was also two stage. The only single stage, similar to your second picture, came on panels, not suburban. Don't know where/who you got the single stage spring from or what year truck? I assume the difference in the two, two stage coils available for your Burb are "wire diameter" which is one of the factors that determines spring rate. You will have to study up to find out how to tell one from the other and if you actually have the optional "heavy duty". While your springs do look stock, I do not think they should be touching without load. The center coils do touch first however. This seems to be introduced in 1963. Some folks call the two stage, "progressive". If you find a donor pair of two stage, standard duty that are not touching, they will ride just fine. The two stage you show are on "heavy duty" all the time. wink
Another option was a leaf spring helper in rear.
