Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, crenwelge, Wayne67vert), 182 guests, and 5 robots.
Topics128,282
Posts1,058,494
Members48,490
#11557 05/04/2005 2:23 PM
Is it necessary to remove the top cover on an SM420 if you're going to pull it along with the engine? It looks awfully close getting it under the floor pan opening. Also, is a chain rated at 1000# heavy enough? (~750# engine + ??? # tranny)
Thanks guys
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#11558 05/04/2005 2:33 PM
My '48 shop manual says to pull the tranny with the engine but it was a pain. I wished I had dropped the tranny first. You probably have more front-to-back room in your '59, though.
[img]http://www.sandeace.com/48/PullingEngine.jpg[/img]
#11559 05/04/2005 2:56 PM
yes, you should remove the cover - or better remove the trans first, or else take the whole 'doghouse' off if you value your sheet metal! not hard really, and sure makes the whole thing easier
#11560 05/04/2005 3:10 PM
I have the front clip off now so I'm not worried about that sheet metal but the floor clearance still looks tight. It sounds like a good idea to drop the tranny. Cherry picker through the door! What fun!
Thanks guys
#11561 05/04/2005 3:46 PM
I took the cover off the 4spd on my 67 GMC when I pulled the 250 w/ trans attached for an engine swap, but putting it back together found it easier to put the trans in after the 327
#11562 05/04/2005 4:42 PM
I put a 4X4 acrooss through window openings in the doors and used a come along to pull the transmission. I let it down onto a dolly and pulled it out. I've done it both ways and think that it's much better without the transmission because the engine is easier to balance fore and aft. Jim
#11563 05/04/2005 5:40 PM
8
8 Offline
You can't get the bell housing off until the input shaft is out of the way and you can drop the clutch and flywheel anyway. I would pull the motor first and trans second.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#11564 05/04/2005 7:15 PM
If you can borrow of rent a transmission jack, life will be good. They have pitch/yaw/roll adjustments and make a reinstallation a piece of cake.
