| | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | My 63 ' three on tree '. column shifter keeps jamming. Any tricks to fix or on adjustment. Tnx. Ron Loudonville NY | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | You've read and followed the repair manual instructions?
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Dec 2012 Posts: 11 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 11 | Without going into too much detail, there is a hole in both arms sticking out of the bottom of the steering column (inside engine compartment). You may have to loosen or remove one of the shift linkage, but slide a drill bit of correct size into both holes to align the arms. Make sure the trans is in neutral, then adjust both shift linkages (at the trans) so they just slip into the trans shift arms. With the neutral shift points adjusted, remove the drill bit and you should be able to shift through the gears. Of course, if you have worn bushings or shift arms then you'll have to fix them first. And of course, you'll never win a drag race w 3-on-the-tree shifting, so be sure to be accurate w your column shifter. I love mine but still get it jammed up once in a while. | | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | Thanks for excellent responses. I have read about bushings; how do I access them? Also, I've seen utube videos about tightening up adjustment, but my '63 unit doesn't have a second bolt on a collar that you can whack to adjust collar. Mine just has one bolt that holds the adjustment.
| | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | My 60-66 manual doesn't seem to address this issue fully. | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | After ten years or so on a home-made floor bracket I went back to the column shift.
With the wheels chocked, sit in the driver's seat and the column shifter in neutral. THE POSITION OF THE SHIFT LEVER SHOULD BE HORIZONTAL, NO IFS, BUTS, OR MAYBES. The shifter should easily glide back and forth within the neutral gate without obstruction. Lightly tape the shifter in the horizontal position.
In the engine compartment loosen the adjusting rods . You may need to do this to CREATE THE HORIZONTAL SHIFT ARM IN STEP ONE.
Underneath the truck at the transmission ensure that each shifter is in it's neutral position by shifting the arms by hand one at a time.
Shifter in neutral, transmission in neutral you return to the engine compartment to adjust rods of free play.
IF YOU HAVE PIVOT POINTS WITH WORN OR OVALIZED PIVOT POINTS...you need to visit a vendor for replacing these worn bushings, they are cheap, do it anyway.
That is the basics as I know it from a previous generation of shift column. My column shifter is easy shifting and shifts easily and surely as I have made several modifications that I won't go into here as I have a '49 column shifter with home-made, bent and threaded rods going to a '69 3sp+od transmission.
You can do it and it will shift well, it does take time.
Good luck!
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The adjustments & bushings are important but if it hangs between gears you usually need to o-haul the shift box. Youcan disassemble it & build up the worn places with weld & grind them down. Rub the top cover over sand paper to take up the wear in the holes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Wrenchbender and others, Welding and grinding these shifting nibs back to stock is doable but I do not know what un-worn ones look like. Are these things blocky looking, with very slightly rounded edges? Maybe a picture or two of a great functioning set. I am going to be removing my steering column in the next couple days to cut it, add u-joints, and collapsible shaft, so figure I will restore it from wheel down. Perfect chance to do some weld buildup. thanks, Cavebull | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | For what it is worth here is what I am dealing with. https://www.flickr.com/photos/dodsonbrett/26149183986/in/dateposted-public/For lack of better terms, lets go with 23 Lever, 1R Lever, and tube Lever. 1) Tube lever looks like it needs material added top, bottom, and upper and lower middle. 2)23 Lever - is it supposed to be rounded like this? 3) 1R Lever - it looks like it needs corners added to and squared. Lengthened too maybe? Cavebull
