6 members (Slick Willy, dunfire, tclederman, KEVINSKI, Gdads51, 68ironhead), 120 guests, and 2 robots.
Topics128,082
Posts1,056,303
Members48,441
#115576 02/19/2005 12:18 AM
I'm looking at getting set up to paint. At this point I don't have any equipment. The Turbine Systems look like a good way to go. Its all new to me, what say the painting experts?
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#115577 02/19/2005 3:40 AM
Apprentice
Apprentice
I sell painting equipment. and just looking at finish a turbine is awesome. A turbine system is a "true" hvlp system. Most use about 8psi at about 60-80 cfm. BUT they are SLOW when compared to hvlp hooked to a compressor or good old conventional. Now
with that said they are good for home owners because
moisture problems are almost nonexistant and some of
the cheap ones do a fantastic job. Like always you get what you pay for. thanks Chris
#115578 03/10/2005 12:13 AM
I knew a guy that painted his Karmann Ghia with a vacuum cleaner. Looked okay for a driver! He found a kit that used the outlet as an HVLP air supply. This was before HVLP becme a household word. I think Filter Queen stills sells a painting attachement for their units grin .
#115579 03/10/2005 12:44 AM
I'd like to see some info on this too. I've never heard of "Turbine". I've always been a conventional guy. Where does a person find out more about this?
Keith
If it were easy they'd have grade schoolers doing it!
#115580 03/10/2005 12:59 AM
TP Tools sells HVLP turbines and has some info on them too. I bought one from them and used it to spray the top inside half of the cab when I had my windshield out. I'm a novice. I didn't even know how to ajust the gun so, I just set everything that could be adjusted in the middle and had at it. Did a great job - I found out that I didn't prep well enuf (shouda sanded more to get the scratches out) but the paint went on great without runs and I was spraying fast and jumping in and out of the cab a lot. Here's the webpage for that episode:
Windshield Epic - A gasket too far
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#115581 03/10/2005 4:31 AM
I used an Accuspray 2-stage turbine HVLP auto refinish system on my 1954 Suburban (PPG single stage DDC Urethane finish). I am told that the results are superb.
I chose a turbine system because I did not have a large compressor and did not want to spend a lot of money on air drying apparati. I had no money invested in a compressor, air drying system, and paint guns/equipment.
The money I saved on paint, using an HVLP system, paid for for the Accurspray set-up. I chose Accuspray (23K) because of the reviews about its spray gun (and the fact that the gun is a non-bleed type). For my next paint job, I will purchase an Isaac gravity-feed non-bleed gun for priming.
I bought the system from Compliant Spray Systems .
Here is some general information about HVLP painting systems .
Advice/Warning: if you will be using Epoxy or Urethane paint, buy/borrow/rent an air-fed "spacesuit" to cover every part of your body and to provide you with fresh air for breathing. These materials are dangerous.
Tim
#115582 02/10/2006 2:07 PM
Junior Member
Junior Member
I am using a Croix turbine system. Seems to work well. I am shooting single stage Centari. The only problem with the turbines are they tend to warm the air so you have to use high temp reducer.
Jeff Lewis
#115583 02/10/2006 2:14 PM
I just sold my Lexaire LX75 system that I bought new in 1989. I used it to paint one airplane and two cars. The plane turned out great in 1990, but the cars were a disappointment. The turbine creates a lot of heat, so you must use high temp reducers. I believe my problems stemmed from the change in paint systems from 1990 to 2004. I had horrific orange peel that had to be sanded out. My buddy who is a pro paint & body man said the problem was a lack of air pressure. Whatever the case, I have switched to a DeVilbliss HVLP and love it. Good luck.
