7 members (Gdads51, 55shaker, greenie-reddy, UtahYork, 3B, Peggy M, joe apple), 125 guests, and 3 robots.
Topics128,259
Posts1,058,291
Members48,485
#1155566 03/18/2016 4:28 AM
I'm trying to locate the cap set screw that fits on the starter pedal. Mine has been missing for years. The round pedal screws onto the starter pedal shaft on the cab floor. An additional set screw keeps the pedal from unscrewing from the shaft.
Does anyone know what the thread pitch, diameter and length of that set screw is?
Thanks.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
I've never seen one with a set screw. It should have a back up nut to lock it.
MarkT #1155586 03/18/2016 10:21 AM
ODSS President
ODSS President
This ^^^ has been my experience.
~ Cosmo
1949 Chevy Half Ton
Sorry. Forgot to mention. Its on a 56 Chevy 3200 235. It's weird because there are threads for a set screw in the cap of the pedal with maybe a 1/4" depth. The reason I ask is because I occasionally have to keep tightening the pedal on after a few months of driving.
It goes right into the center of the button (2012) in Tim's link.
Take it off and go to your local bolt/nut supplier and find one to fit.
The Assembly manual does not show a set screw. It only shows the button, rod, bellows, and the lock nut.
Bill Burmeister
MarkT #1155683 03/19/2016 12:21 AM
I don't know about the '56 stomp pedal, but the AD ones are National Pipe Thread and should not ever come loose due to the tapered thread. The lock nut is at the other end of the shaft.
Carl
It's been a while since I've had mine apart, but that sounds right for the '55-'59s as well, Carl. The locknut is on the bottom, same as AD.
Bill Burmeister
