| | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Hi. The stud that holds the vent window lever is missing from the frame. Is there an easy fix for this?
I am thinking that it is a big job to replace the entire frame. Also, I don't really like the idea of sealing the window shut.
Thanks. | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | The pivot is peened/swaged to the saddle, which is riveted to the frame. If you can find a donor frame, you can pull the glass, drill the rivets and install the new saddle. John | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | And don't limit your idea of donor frame limit you... Any number of makes and years work for those parts.
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | If you are able to make the repair without replacing the entire frame please provide an update on how difficult it was and if you feel it was a success. I have the same scenario and have been trying to determine if I should try something like described above. Thanks. | | |
