11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible),
109
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'm trying to locate the cap set screw that fits on the starter pedal. Mine has been missing for years. The round pedal screws onto the starter pedal shaft on the cab floor. An additional set screw keeps the pedal from unscrewing from the shaft.
Does anyone know what the thread pitch, diameter and length of that set screw is?
Thanks. Mark
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've never seen one with a set screw. It should have a back up nut to lock it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I've never seen one with a set screw. It should have a back up nut to lock it. This ^^^ has been my experience.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Sorry. Forgot to mention. Its on a 56 Chevy 3200 235. It's weird because there are threads for a set screw in the cap of the pedal with maybe a 1/4" depth. The reason I ask is because I occasionally have to keep tightening the pedal on after a few months of driving. | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | It goes right into the center of the button (2012) in Tim's link. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Take it off and go to your local bolt/nut supplier and find one to fit.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The Assembly manual does not show a set screw. It only shows the button, rod, bellows, and the lock nut.
Bill Burmeister | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I don't know about the '56 stomp pedal, but the AD ones are National Pipe Thread and should not ever come loose due to the tapered thread. The lock nut is at the other end of the shaft. Carl
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's been a while since I've had mine apart, but that sounds right for the '55-'59s as well, Carl. The locknut is on the bottom, same as AD.
