| | | Forums66 Topics128,034 Posts1,055,542 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 47 | Ok Guys, so I am building up my freshened 54 235 and will be converting to 12 volt. So my question is whether this will affect the points and condenser in the distributor. I don't want to switch to HEI just yet.
Thanks!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You will need to change the generator, voltage regulator, and coil to 12v (and light bulbs and any other 6v devices/gauges). There is a Tech Tip here about that change. You will need a ballast resistor somewhere in the ignition circuitry before the coil (or, you will burn the points). You could use a 12v coil with built-in ballast resistor, but there are advantages of have an external ballast resistor and wiring the starting circuitry to all full 12v current while cranking/starting. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Will not effect the points and condenser.
Evan
