9 members (JW51, Gdads51, SmalltownTRKGuy, HandyAndy, Hotrod Lincoln, 48jim1ton, baldeagle, cmayna, Otto Skorzeny), 74 guests, and 1 robot.
Topics128,049
Posts1,055,634
Ok Guys, so I am building up my freshened 54 235 and will be converting to 12 volt. So my question is whether this will affect the points and condenser in the distributor. I don't want to switch to HEI just yet.
Thanks!!
You will need to change the generator, voltage regulator, and coil to 12v (and light bulbs and any other 6v devices/gauges). There is a Tech Tip here about that change.
You will need a ballast resistor somewhere in the ignition circuitry before the coil (or, you will burn the points). You could use a 12v coil with built-in ballast resistor, but there are advantages of have an external ballast resistor and wiring the starting circuitry to all full 12v current while cranking/starting.
Will not effect the points and condenser.
Evan
