Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1155489 03/17/2016 8:13 PM
Hi. The stud that holds the vent window lever is missing from the frame. Is there an easy fix for this?
I am thinking that it is a big job to replace the entire frame. Also, I don't really like the idea of sealing the window shut.
Thanks.
Stove #1155527 03/18/2016 12:37 AM
The pivot is peened/swaged to the saddle, which is riveted to the frame. If you can find a donor frame, you can pull the glass, drill the rivets and install the new saddle. John
And don't limit your idea of donor frame limit you... Any number of makes and years work for those parts.
Give me ambiguity
or give me something else
If you are able to make the repair without replacing the entire frame please provide an update on how difficult it was and if you feel it was a success. I have the same scenario and have been trying to determine if I should try something like described above. Thanks.
Dave from Northern Kentucky
My 54 3100
Moderated by  ndkid275, Phak1
