| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | 1951 3100....Going back with all the original tie rods and drag link. All appear to be tight and in good working shape. Dis-assembled all of it, cleaned it, anti-seized all of it, (I'm a big fan of anti-seize). My concern is any and all of the joints being exposed. Certainly they had some type of rubber seal or boot that covered the joint (ball/stud) when it was produced, or maybe they didn't. New designed tie rods have the rubber cup that protects it from grit and grime, and also holds the grease in. Is there anything made for these? Did they come with something originally? I can fabricate something, that would be functional and look fine, but I would prefer to go back with whatever may have been used originally.
Thanks, Mike
Mike
1951 3100 5 window
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Considering the long oval slot on the original tie rods and drag link, the ones from O'Reilly appear to be what they would need to look like. I suppose I'll fabricate them.
Thank you sir.
Mike
1951 3100 5 window
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The Factory Repair Manual recommends greasing those every 1,000 miles. A lube schedule, that frequent should be sufficient to force the grime out, protecting the joints. Carl
| | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Probably won't put 1,000 miles on it in a year. But wanting it to be correct, like it was originally, means something. If I was to speculate, they most probably didn't have any type of cover/seal on them when it was made. Just wanting it to appear correct. Too much attention to detail maybe...........
But thank you Cal.
Mike
Mike
1951 3100 5 window
