8 members (SNOYL, Southerntruck, Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag),
155
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I'm continuing work on my Suburban (1950) by patching and cutting. I have a question about the lower rear valence area that bolts onto the lower left and right rear corners. There are a couple captured nuts on the inside of these two out and lower corners. Does someone have a picture of this area and the part that bolts to each corner below the tailgate area? Seems like I am missing this piece. Related: I see that Jim Carter's catalog has parts for this area (SM574, and SM575) but I am not sure where these are located and wondering if these are the sheet metal parts I need. (?) Thank in advance. Tom my email is: [email protected] | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Those JC parts are for above the rear valance (stone shield?). I do not like to try to search JCs site, but here are the lower rear panel-body repair pieces: left right OK - I found them on JC's site: JC left? JC right? JC's parts seem to include the captive nuts needed to attach the hangers for the rear-valance/rear-stone-shield | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Thanks, Tim. This helps. Looks like I need to find or fabricate two end brackets for the stone shield. And if I understand correctly the brackets bolt to the inside of the lower rear corners using the captured nuts.
Thanks again. Tom
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tom,
Two brackets at lower rear corners, and I think two brackets equi-distant underneath the rear valance/stone-shield.
I am not near my Suburban, or I would offer to take pictures. Maybe someone will do that for you?
Good luck,
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Tom, I can take the pics you need. Let me know. My 49 should be the same.
Weeds
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Thanks! I am in need of a photo or two of the brackets that attach to the lower rear corners and the rear gravel shield. Found a NOS gravel shield not long ago but missing the brackets.. Not sure what they look like and where to find them. Thanks, Weeds. PM sent.
tom | | | | | Joined: Feb 2016 Posts: 18 New Guy | | New Guy Joined: Feb 2016 Posts: 18 | Wow, talking about finding a needle in a haystack! Thank you so much for posting a source for those rear corner patch panels! You are a true life saver. Thanks again, kyron | | | | | Joined: Feb 2016 Posts: 18 New Guy | | New Guy Joined: Feb 2016 Posts: 18 | Just went to dmv yesterday to register my 53 suburban and only had the serial number on door jamb. Turns out my 53 is really a 52! There isn't any difference between the two years is there? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1953 changes from 1952 (most info from JC): Door post ID plate is now blue & silver. Prior years were black & silver Hood front emblem now stainless steel Series/model emblem on sides of hood changed (same as 1954)
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | THANK YOU for posting these photos. This is just what I needed to see. I can now look for the corner brackets seeing that I now know what they look like. Thanks for taking the time to post these pictures. They are a big help. tom | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | If any one has a lead on NOS brackets or a valance I'd really appreciate it. Thanks for posting these pictures as I also needed the information. Living in the rust belt makes life difficult!
Still trying to get ole Betsy back on the road.
| | | | | Joined: Jul 2010 Posts: 59 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 59 | Might try Ray Stanley over on Oldgmctrucks.com. He's restored/rebuilt a few valances. Not sure what his turn around/work load is like but his work is top notch!
1955.1 GMC Suburban Hydramatic
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | thanks! I found one good corner bracket in the box of parts that came with the truck -and the other corner bracket broke in half. I guess I could weld the broken bracket and use it - not ideal - but its not a piece that sits in plain view either. Or attempt to make a new one...shouldn't be too complicated. thanks to all for the help. Very much appreciated.
tom | | |
