5 members (Wally / Montana, Chris's 46 / 515, mick53, Stovebolt48, 1955 1 Series), 133 guests, and 3 robots.
Topics128,189
Posts1,057,337
Members48,469
#1155412 03/17/2016 4:13 AM
will a 4 speed from a 46 1 ton gmc fit into a 46 1/2 ton chevy? any help? the gmc is a 228, the chevy a 216.
3B Offline
Hy jetmech6868, the short answer is yes, but the one ton may be an open driveline type while the half ton will be a closed driveline type. Parts can be swapped between the two transmissions to configure it to what you require, if both transmissions are closed driveline type then they might be a direct swap. The only issue then might be the universal joint size but you should be able to swap output yokes, hope that helps.
P Online: Content
A 4 speed is wider so the brake master mount where it mounts to the transmission will need to be modified.
3 Speed and 4 speed mounts are different from the factory, but a 3 speed mount can be modified be shortening the mounting pedestals.
My Blog
My 46 is a 4 speed. Thanks for the input. I can give it a try.
