0 members (),
128
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 5 New Guy | | New Guy Joined: Jun 2015 Posts: 5 | I have a 54 3800 tow truck that's in pretty decent shape, I would like to put the cab and front end on a 3100 frame. Will any early 50s frame work? Or do I need a 54-55 frame. Thanks a lot for the help guys | | | | | Joined: Jul 2010 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 36 | I personally will want to cry if you do that. A 1 ton tow is a fairly unique truck. Maybe not the same value as 1/2 ton. If you want a 1/2 ton, it would be a lot easier to buy one. I see them for sale all the time. What are you going for? A stock 1/2 ton or daily driver/street rod? IF stock and still want to swap, a '54 will have better gear ratio. I don't know if cab mounts changed over the years. If driver/rod, you might as well go with an S-10 frame. You get all updates at once. Sorry if I sound harsh, but I would love to have that '54 intact. If you do the swap, post the rest of it for sale here. I might come get it & put a 1/2 ton cab on it. (joking) ( might still come get it & I'm in CO) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Cab mounting changed after 1948. With some holes drilled you can use either mount on either frame. | | |
