7 members (Woodcmiami, LAROKE, Hotrod Lincoln, Southerntruck, MNSmith, gswbbc, 1 invisible),
117
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 7 New Guy | | New Guy Joined: Mar 2016 Posts: 7 | I’m indecisive help…
I am looking for truck that I can use around the property but one I can enjoy and fix up. I started out looking for a 1 ton flatbed but I have yet to find one in good condition. What I have found are a 1949 / 4400 and a 1954 / 6400. Here are the pros and cons:
1949 161” wheel base The body is in great shape. Cab corners look good, bottom of the doors look good. It has 7000 miles on it. The Current owner has spent 1500+_on the brakes Tires are dry rot. All glass is intact but I be window seals are britial. No Bed. It is a former fire truck and was bought for the bed. I will have to have it shipped to the house. Stock 4 speed and single speed rear
1954 161” wheel base Running and driving. It is currently in use as a farm /grain truck It has 50,000+ miles on it. (From the interior wear I wonder if it is 150k) It has minor rust, bumps and dents on the body. The driver’s side floor board is (rusted through) The interior is worn out and (seat worn to the springs, every interior panel will need to be replaced) Brand new tires and one piece rims. 12’ dump bed that works but the floor is rotted and patched with plywood. Stock 4 speed with 3speed aux. transmission. (.87 overdrive, I believe) I could drive it home.
What would ya'll do they are the same price. Is the frame on the 6400 just thicker than the 4400? It looks like they have the same tires, and springs.
One thing I have not researched is would they have the same engine?
I'm stuck, overdrive and new tires is nice, but no rust is good also.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ykp53, welcome, well that is a dilemma for sure! I am not 100% sure but I think the 6400 might have a 261 in it and the 4400 would have a 216 or 235. In any event the 54 will have a precision bearinged engine. If you have the space and facilities I would be inclined to buy both of the trucks and build one out of the two and sell what you have left. As you have seen by the bill the cost of the brake system overhaul is expensive and you will probably have to do the same to the 54 if you buy it alone. I realize you only wanted a truck and not a project, but that is my best advice, hope it helps. | | | | | Joined: Mar 2016 Posts: 7 New Guy | | New Guy Joined: Mar 2016 Posts: 7 | I tried the lets by both line... that didn't go over well. Half the fun is "the project" I just need to be sure its not something that is out of commisiion for a long time. I need to be able to repair and use.
is the 261 that much better than the 235? what is the precission bearing vs standard. I am used to 50s straight 6 mopars. How does this engine compare in reliability?
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | they put the 235 in the 6400 as well. I have a 55.2 6400 with 235. If the 54 is running and driving, I would assume the brakes at least work. 1500 to have the brakes gone through is probably having someone else do the work. If you can do the work yourself, it should be cheaper than that. I would go with the 54, tires can get expensive as well as a dump bed! | | | | | Joined: Mar 2016 Posts: 170 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 170 | I'd get the '54. Likely better motor, the tires and 1-piece rims are a HUGE plus. You can do your own brake job to save money, but you can't build your own tires/rims. You did say the rust is minor, and you can drive it home! I don't think anything could be more satisfying than driving it home the first time. I wish I could have done that with mine.
You may find a dump bed to be super useful as well. You could turn it into a flatbed with removable lower-profile stake sides (that's what I'm doing).
Does the 6400 have a 2-speed rear, or just the 3-speed aux trans? Either way, I'd be very jealous of your overdrive. I may do a motor swap for more power someday, but that won't make it go any faster if I keep the RPM's in check... | | | | | Joined: Mar 2016 Posts: 170 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 170 | they put the 235 in the 6400 as well. I have a 55.2 6400 with 235. If the 54 is running and driving, I would assume the brakes at least work. 1500 to have the brakes gone through is probably having someone else do the work. If you can do the work yourself, it should be cheaper than that. I would go with the 54, tires can get expensive as well as a dump bed! Shoot, you beat me to it! | | | | | Joined: Mar 2016 Posts: 7 New Guy | | New Guy Joined: Mar 2016 Posts: 7 | You did say the rust is minor, and you can drive it home!
Does the 6400 have a 2-speed rear, or just the 3-speed aux trans? Either way, I'd be very jealous of your overdrive. I may do a motor swap for more power someday, but that won't make it go any faster if I keep the RPM's in check... The cab corners are showing some signs of rust but they are still intact. however the floor plans are gone. How hard are these to replace on a chevy? it only has the aux 3. no high low. imagine under driven first with a high low rear and I could pull anything. but I don't know if I would ever use a 12' dump bed. I need something to haul a few bales of hay and brush/logs
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "is the 261 that much better than the 235? . . . . .what is the precission bearing vs standard"
The 261 is noticeably more powerful than a 235 - to most people, that makes the 261 better.
Prior to the implementation of precision insert rod bearings in all engines, all 216 engines and most 1953 and earlier 235 engines had babbitted rods (no insert/removable bearing). | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Are you sure the '54 has one piece rims? Confirm the tire size... If they are 22.5" they are in fact 1-piece tubeless rims/tires and are hard to find in the 5/10 lug pattern...those rims could be worth $100 or more each. Mike B  | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | If you're buying the truck to use, than the one with the bed would probably make more sense. You'll use that hoist more than you might think! But I can appreciate the dilemma you're in- I'd probably still try and get both!  Sometimes it's easier to get forgiveness than permission! | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | You could sleep in one if you get both of them.  | | | | | Joined: Jan 2015 Posts: 25 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 25 | I got a 48 6400 from my brother, ex-grain truck. I use the heck out of the dump bed. Actually, that and the 74 GMC I have are my favorite trucks to use around here. Something about the older trucks.... | | |
