5 members (Wally / Montana, Hotrod Lincoln, Otto Skorzeny, 78buckshot, Ridgeback), 211 guests, and 2 robots.
Topics128,087
Posts1,056,115
Members48,435
1 Offline
Does anyone know approximately how big of a gap there should be between the bottom of the bed wood and the top of the frame rail at the area where the frame humps up over the rear axle?
The truck in question is a 1949 3100.
I have a 3/8 inch gap at the rear most mounting points (even after adding the rubber mounting pad and I cannot figure out where this error is coming from. I have about a 1/4" gap between the bottom of the bed and the top frame rail where it humps over the rear axle. I am trying to figure out if this is normal or if it should be closer. When I tore mine down all of the bed wood and mounting blocks were rotted away and it was sitting on the frame.
I will probably end up just making a 3/8" spacer for the rear most mounting point.
What are the dimensions of your wood blocks at the front crossmember and next to last crossmember?
1 Offline
The blocks are between 2 1/8" and 2 1/4" tall and the rubber pad under them is 1/4" tall. This corresponds to most of the other block measurements I have seen here on the forum.
Yellowboy: You may have already taken this into consideration, but, have you taken into account the relationship of your bed and rear fenders and their alignment to the trailing edge of the running boards? You might want to consider getting the running boards and rear fenders on the right plane before you go too far with shimming those spacer blocks. Just a thought....
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
