2 members (ronsway, Nick in Manitou), 108 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#1155172 03/15/2016 6:11 PM
I have a 1949 Chevy 1/2 ton with a 216 engine. I heard a very low scratching noise and found it was the water pump pulley . It was wobbling. I removed the fan belt and found the fan was loose. I thought I would tighten the fan bolts and problem fixed. The bolts were already tight. Mind you the truck is not overheating or leaking at all. I removed the fan , but I can not remove the pulley. I don' t know why the pulley won' t tighten up. Any idea fellows what can be wrong before I have to remove the water pump.
Sounds like the water pump bearing is bad. Others ideas will be along shortly.
Sir Searchalot
Sir Searchalot
Lets back up here. Just fan was loose? But bolts were tight? What do you mean by loose? Pulley tight but fan loose with tight bolts?
You could just leave fan off and install whatever bolts will not be too long, install belt and run motor to see if pulley still "wobbles".
Before running motor and before putting on belt, try to wiggle pulley by hand to detect pump shaft movement.
H Online: Content
The pulley is pressed onto the water pump shaft. If the pump isn't leaking now it will be soon. Change the pump. The shaft bearings are worn out.
Jerry,
You're a wealth of knowledge. Just so you know, I learned something new today.
Thanks!
P.S.
By the way, I finished drilling my crankshaft and tapped the threads on Saturday. Tried the bolt I bought to be installed after pulling the Harmonic Balancer on and it threads in fine. The tool and your guidance are well appreciated.
Sir Searchalot
Sir Searchalot
Even after some dirt track roll overs and a bike laydown, he still has it. Hard headed I guess.
No, the shaft seems to be alright. Just the pulley. I took the fan off and added a couple of extra washers to the bolts and reinstalled the bolts with no fan , the bolts will tighten up, but the pulley is still wobbly.not the shaft just pulley.
When buying a new pump does the pulley come installed on pump or do you use your own? Or buy it separately? I am thinking the pulley got unwelded or detached from the pump shaft somehow. ?
H Online: Content
The new pump comes with the pulley attached. If it's wobbling, the press fit on the pulley has gone away, and it cannot be re-established. If the pulley is indeed loose on the shaft, it would be the first one I've seen like that since I started getting paid to fix cars and trucks in the mid-1950's.
http://www.classicparts.com/images/82-011-th.jpg
Yes, I believe that is what has happened. Thanks for all the quick response. I guess I will have to replace the water pump after all.
Is the pulley loose on the shaft (the round end in the middle of the pulley?
Yes, the pulley is loose on the shaft. The shaft bearings are good, no leaks no overheating ,because the pulley catches enough to turn the shaft.
If that is the case, use a three jaw puller to remove the pulley so that you can see where the damage is (shaft or pulley).
Carl
