5 members (Maybellene, Wheelie, Otto Skorzeny, Gdads51, MarkT), 161 guests, and 1 robot.
Topics128,078
Posts1,056,022
Members48,433
#1154942 03/14/2016 1:23 PM
Y
Y Offline
Is there any thing that makes one better than the other ( other than cosmetics)? is there any major mechanical differences?
54 has a one piece curved windshield. 49 2 flat pieces with separate bar in the center. Maybe Tim Lederman will chime in or someone else with more kniwledge
me. I am sure there are more differences but I am not the expert.
Weeds
24601
You're quite correct, Weeds -- we have a lot of people who use this site who are quite knowledgeable (and shouldn't be afraid to share). No one has exclusive expertise rights around here. wink
In the meantime, ykp53, check out our TechTip section (see the menu bar at the top of the page) -- several good articles there that might help you.
Welcome to Stovebolt!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
1949 vs 1954
There are differences, but you can judge which is better.
You might assume that 1954 would have improvements over 1949?
1949 -vs-1954
low pressure, babbitted rods 216 (up through 1953) -vs- high pressure insert rod bearings 235
4.11 rear end (up through 1953) -vs- 3.90 rear end
huck brakes (up through 1950 in 3100s) -vs- bendix brakes
cloth-covered wiring (up through 1952) -vs- plastic-covered wiring
The 1954 bed/tail-gate is redesigned (and became the standard "step side" bed design for many years).
Many more color combinations in 1954 - interior and exterior.
As ykp53 noted: there were many cosmetic changes in 1954.
It seems odd that GM made the cosmetic changes, since major changes in design would show up a year later (in late 1955).
Only other main difference is the '49 has knee action shocks vs tube shocks. '49 has solid door glass & '54 has vent windows.
Wasn't the bed deeper on the 54? Or was that 55?
Larry W.
1953 3800 Dually Flatbed
The bed changed in 1954 - deeper with flat top rails.
As posted above, the same bed dimensions were used from 1954 for many years forward.
However, the bedsides in 1954 were "embossed" around the wheel wells - later years bedsides were flat.
If you want the know many of the changes in 1954, this 1954 Engineering Features booklet provides B&W illustrations and descriptions.
Most of the custom/show truck builders like the one piece door glass of the 47-50. Also notice that most of the winners use the 3 window cab even though the 5 window cab is more popular with the street crowd.
Evan
