0 members (), 122 guests, and 2 robots.
Topics128,131
Posts1,056,727
Members48,454
Y
Y Offline
I am looking at a 54 6400 that has a 4 seed with a 3 speed aux transmission. Was this a factory option? With the aux transmission what would be the truck top speed?
All depends on the ratio in the auxiliary transmission, as well as engine RPM, axle ratio, and tire diameter.
Some auxiliary transmissions are still 1:1 or direct drive in high, no increase in top speed. Others can have overdrive ratios up to about 0.73, other common ratios are about 0.85 and 0.80 plus or minus a little given different makes and models.
To calculate road speed input the values here.
http://www.onlineconversion.com/bigger_tires.htm
Put your auxiliary ratio in for the "transfer case" ratio.
•1952 Chevrolet 3800 pickup
---All pictures---
