1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1154641 03/12/2016 3:36 AM
Help,
I've searched the forums, got an apology from my local NAPA dealer and spent hours searching the internet for a parts source for the 4 inch wide drum brakes on my 1956 C6500 2 ton truck.
The part I need looks similar to this but it should be a single spring, not two like the one in the picture.
spring
Big Bolt Forum Moderator
Assuming those are the shoe return springs, not sure if they are the same but, I bought some Raybestos H9226 springs off Ebay for my 1958 6400.
http://www.ebay.com/itm/151853414908?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Mike
Whoo yah, not the same as what you needed but I found them when I searched the other parts offered by the seller. thumbs_up
Has anyone upgraded from a single master cylinder to dual master cylinder power brakes using this kit? Scroll to the bottom of the page and my apologies in advance if this is considered a plug.
Brake Booster kit
Sweet! That helped you find what you needed then?
Mike
Brake Booster kit
that kit looks like it is for a 1/2 ton. I have one similar on my 59 Suburban. diameter of the master cylinder is too small for a 2-ton. It won't push enough fluid.
Mike
I don't believe anyone make a "kit" for the big trucks, you would need to pull it together on your own. Your '56 6500 MC has a 1-1/4" bore, so that's the bore size you need to look for.
If all of the parts are new you should have many years of good service from the original system.
Make sure all of the lines (steel and rubber) are new as they fail from the inside out, replace/rebuild the MC and wheel cylinders and go through the shoes, adjusters and springs.
Don't forget to make sure the parking brake is in good working order and adjusted as well.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the help. We, my neighbors and I are getting it ready for the road so we can haul stone to fix our privately maintained road. They are both retired and grew up around these trucks plus one owned an excavation business.
They are replacing the brake lines and going through the truck to ensure it road worthy, to date I have been using it around my property and stopping by turning off the engine. lol. ohwell
