| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Help, I've searched the forums, got an apology from my local NAPA dealer and spent hours searching the internet for a parts source for the 4 inch wide drum brakes on my 1956 C6500 2 ton truck. The part I need looks similar to this but it should be a single spring, not two like the one in the picture. spring | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Assuming those are the shoe return springs, not sure if they are the same but, I bought some Raybestos H9226 springs off Ebay for my 1958 6400. http://www.ebay.com/itm/151853414908?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Whoo yah, not the same as what you needed but I found them when I searched the other parts offered by the seller.  | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Has anyone upgraded from a single master cylinder to dual master cylinder power brakes using this kit? Scroll to the bottom of the page and my apologies in advance if this is considered a plug. Brake Booster kit | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Whoo yah, not the same as what you needed but I found them when I searched the other parts offered by the seller.  Sweet! That helped you find what you needed then? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Has anyone upgraded from a single master cylinder to dual master cylinder power brakes using this kit? Scroll to the bottom of the page and my apologies in advance if this is considered a plug. Brake Booster kitthat kit looks like it is for a 1/2 ton. I have one similar on my 59 Suburban. diameter of the master cylinder is too small for a 2-ton. It won't push enough fluid. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I don't believe anyone make a "kit" for the big trucks, you would need to pull it together on your own. Your '56 6500 MC has a 1-1/4" bore, so that's the bore size you need to look for. If all of the parts are new you should have many years of good service from the original system. Make sure all of the lines (steel and rubber) are new as they fail from the inside out, replace/rebuild the MC and wheel cylinders and go through the shoes, adjusters and springs. Don't forget to make sure the parking brake is in good working order and adjusted as well. Mike B  | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 | Thanks for the help. We, my neighbors and I are getting it ready for the road so we can haul stone to fix our privately maintained road. They are both retired and grew up around these trucks plus one owned an excavation business. They are replacing the brake lines and going through the truck to ensure it road worthy, to date I have been using it around my property and stopping by turning off the engine. lol.  | | |
