0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I've done a lot of searching and there is a lot of information about the fan and water pump location for a 216 to 235 swap. I can't seem to find any info about the radiator. My 216 radiator is a 0 lb one. Will this work for a 235 swap or do I need another radiator that needs a pressurized cooling system? Thanks.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | A clean 216 radiator works very well with a 235 especially one with the relocated water pump Jerry
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Original radiators work great! Have a good radiator shop go through it and tell you its good, then get Pre'68 Daves water pump adapter so your fan is in the center of your radiator, and you have it made. Doing it right may be more expensive than doing it half-fast, but it's COOOOL! I use a 4 pound cap just for good measure on that 0 pound radiator.
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | Rusty, what year is your truck?
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Sorry I didn't put this in my original post. It's a 1947 AD 1/2 ton.
