3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#1154174 03/09/2016 3:50 AM
I have a 1953 Chevy truck and I changed the front tie rods to modern tie rods . My question is can I run p 235 75 r 15 tires in the front without clearance problems ? I have a 15 by 7 rim in the front with bias plys but want to use radials instead
sal moreno #1154433 03/10/2016 6:07 PM
Not sure
sal moreno #1154469 03/10/2016 9:46 PM
What size are your bias tires?
My 46 GMC on Photobucket
sal moreno #1154481 03/10/2016 10:50 PM
As long as the wheels have the correct backspacing (no more than 3 1/2"), that size will be fine.
Bill Burmeister
sal moreno #1154495 03/11/2016 12:54 AM
I am running 235x75x15R and have no problem with them as long as your back spacing is not to great. root
sal moreno #1154496 03/11/2016 12:56 AM
I'm not sure what size my rims are, but I've got 235/75R15's on my 51, no problems. Curious about the tie rod end swap. I need to check mine, did you just replace the ends or are other parts needed? John
tinnerjohn #1154541 03/11/2016 6:21 AM
Actually I want to run 215 75 r15 in the front . I got rid of the originally tie rods and using modern tie rods .
