1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#11543 05/14/2005 12:43 AM
My '49 Burb has 4 wheel disc brakes with the master cylinder mounted on the drivers side frame under the cab.
I have to pump the brakes at least once to get a decent pedal. We've pressure bled the system twice...there are no leaks and there is plenty of fluid in the system.
I've recently read that you need to install a 2lb "residual" valve in the system when the calipers are higher up than the master cylinder. Is this true? and if so where does this valve go?
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
Thanks for the help...a couple of add'l questions; why do you need them, what do they do?
Steve G.
I've always heard that residual pressure valves will cause disc brakes to drag, because there's no spring pressure to retract the pads, like a drum brake has. At least, when one of my friends used a master cylinder with anti-bleedback valves on his race car, all 4 disc brakes had enough drag to turn the rotors red hot. When we changed to a MC without the residual-pressure valves, the drag stopped happening.
It sounds like you need a MC with a bigger bore size, to displace more fluid on the first stroke.
Disc brakes are supposed to drag against the disc. The reason you have to pump is that they are draining back and retracting too far. Disc brakes should have a 2lb residual valve if the MC is below the wheels. Drums should have a 5 lb residual valve. If you put a drum residual valve on a disc system you will get the same problem as hot rod lincoln.
An MC higher than the wheels solves this with gravity.
Paint & Body Shop moderator
