7 members (TUTS 59, Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, 1 invisible),
129
Mod | | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 1953 Chevy truck and I changed the front tie rods to modern tie rods . My question is can I run p 235 75 r 15 tires in the front without clearance problems ? I have a 15 by 7 rim in the front with bias plys but want to use radials instead | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | What size are your bias tires? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | As long as the wheels have the correct backspacing (no more than 3 1/2"), that size will be fine.
Bill Burmeister | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I am running 235x75x15R and have no problem with them as long as your back spacing is not to great. root | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I'm not sure what size my rims are, but I've got 235/75R15's on my 51, no problems. Curious about the tie rod end swap. I need to check mine, did you just replace the ends or are other parts needed? John | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Actually I want to run 215 75 r15 in the front . I got rid of the originally tie rods and using modern tie rods . | | |
