3 members (Gdads51, TUTS 59, 1 invisible), 119 guests, and 8 robots.
Topics128,088
Posts1,056,124
Members48,435
Trying to remove the rear end filler plug to check and change gear oil (1950 3100) plug seems to have been in there a while tried a 3/4" open end wrench and adjustable Must just be stuck any tips tricks or suggestions ?
Sam
1953 3100
It's a pipe thread, try tightening it slightly then loosen. Also might find a square socket to get a good bite on the plug.
BC
1960 C60 pasture art
Big Bolt Forum Moderator
if you can get a square socket on it as BC59 suggested, you might try an impact. A lot of times, the blows from an impact will knock things loose that don't want to come loose by brute force.
Mike
Thanks guys finally got it! square socket long bar and hammer - I think it may have been it there since the truck left the factory.....
1953 3100
Don't think it's pipe thread, the ones I've run across are straight thread with a gasket.
On stuck ones a pair of Knipex Plier Wrench have worked great for me.
•1952 Chevrolet 3800 pickup
---All pictures---
That's correct. It's straight thread with a gasket. '63 and later have pipe threads for the filler, though.
Bill Burmeister
