| | | Forums66 Topics128,196 Posts1,057,387 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 6 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 6 | I am looking at putting an LS1 engine and tranny in my 1950 Chevy truck and would like to know if anyone has done this and get some help/advice on what is required, ie: front end, engine compartment modifications, etc, etc. Am new and trying to learn. Thanks, | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | It's been done thousands of times and there is lots of info there. You will enjoy your finished truck.
| | | | | Joined: Nov 2015 Posts: 6 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2015 Posts: 6 | Do you know where I can go to seek this info?
Thanks | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Use the search function at the top of the page on this site. Search LS1 swap or a version of that. Should be lots of posts.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Suggest you also pick up a few of the truck magazines - Custom Classic trucks comes to mind. There are a lot of vendors in there that specialize in parts to make the engine, trans, and rear-end swaps into older trucks. No sense reinventing the wheel. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | As already mentioned,this has been done thousands of time,mostly with a chassis swap as well. Are you doing this,or using the stock frame and axle? | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | Good question BC52 Frame? a few other things to think bout, while you decide what it is you in vision for your truck. headers, brake master location, cross members, rear end, steering box & column, fuel tank. some welding is required, with fabrication skills, just figuring out the engine location to the radiator, is a challenge. Have fun, good luck with your project. | | |
