| | | Forums66 Topics128,049 Posts1,055,629 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | I am taking apart my drivers door to replace the door latch. I came upon some fasteners I have never had before. They have a recession that resembles a dog bone. What are they called so I can purchase the bits to remove them.
Larry
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Clutchhead screws. You can find the bits in some places and always look in the old hardware stores for a set of drivers. Any Chevy/GM garage needs a set. Don't throw the screws away. | | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 |
Larry
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Larry, If you do much work on your truck, you will encounter up to 3 different size clutch head screws. If you haven't purchased any drivers yet, Jim Carter Truck Parst has a real nice set of them. They fit better than some of the interchangeable bits that I have used. Go to www.oldchevytrucks.com Hope this helps. Good luck with your project. Rugo
Steve Rugg 53 3100
| | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | I feel stupid for asking but where on his page would you find them? I've looked and cant seem to find them. I'm sure if they were a snake I would of been bitten several times.
Larry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | J C 's clutch head bits Your local hardware stores might have a "security bits" set that include at least 3 clutch head bit sizes. Look in the Links section here. Almost all the reproduction parts vendors also sell clutch head bits. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Try your local RV camper store. The camper industry used clutch heads long after the auto industry did. Usually right on the shelf. | | |
