1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#115340 03/24/2004 2:35 AM
any tips
on the side of a 58 fleetside bed (the bottom of the bullet)
no chrome strip holes to follow, just a gental curve.
Measuring will be difficult i.e. have to go around the bullet to do it.
thanks for any help,
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#115341 03/24/2004 3:44 AM
ya talkin about this kinda thing? need a good eye and a steady hand, ain't no measurin involved, and if yer a 64th off, or even a 32nd, doubt anyone will see it - the problem is ya gotta do it on top of fresh paint! grin
#115342 03/24/2004 3:47 PM
What about getting one of those new fangled Laser line things? They make adhesive pads to stick them to different objects. Just a thought.
The only there way that I have seen it done is by eye. Start the stripe where you want it and then pull 2, 3, 4 feet out and lightly position it, go 2,3, 4 feet more and do the same. Make sure that you have some tention on the tape so when it is right and the press it down it dosen't bunch up in the middle or end. Good luck.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#115343 03/24/2004 5:07 PM
lazer level. . . . now there is an idea smile
but i want to get it done today, and the nearest lazer level would be 70 miles away. frown
i used some "heater duct tape" on one side, it worked a lot better than masking tape because it doesnt sag as much.. . . . it should work. . . maby. cool
thanks,
BrianK
#115344 03/25/2004 12:21 AM
You could use an old boat building trick, a water level. It's a "bucket" or can of some kind with a long clear tube out of the bottom. Place the end of the tube ABOVE the level of the bucket and fill the bucket with water. Now position the bucket so that the water in it is at the level you want the line to be. Take the open end of the long tube any where along the truck and the water level there will be at the same level as in the bucket.
This is how you "scirbe the water line" when you build a boat upside down.(Wooden Boats mostly) There are NO STRAIGHT LINES on a boat and this works great. Sometimes a little food coloring in the water helps, too.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#115345 03/26/2004 11:08 AM
I
I Offline
I ahve never done this And I am not sure that I could but I saw a guy at a car dealership do the plastic pinstriplike this.
stuck about 4 inches how he wanted.
Than he pulled away and out the remainder of the car or panel without sticking it. lined it up and stuck it down.
I have ben trying to mask round corners in my house for straight lines and have been having a tough time.
My wife watches trading spaces grin OUCH
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
