7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#1152799 03/01/2016 5:01 AM
will any factory tach work on my '69 GMC 305 v6 or will I need to find a 6 cylinder specific factory tach?
Thanks in advance, Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Yes, you will need/want a tachometer that matches your number of cylinders.
Some have a 4-6-8 cylinder selection switch.
OK, thanks!
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
here is the tach setup that I'm looking at
(Ebay link deleted)
any clue if it would work in my GMC with the 305 v6?
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
The way to find out is to ask the seller if the truck had 6 in it.
The eBay title states: "73 72 71 70 69 68 Chevy C50 C10 speedometer cluster tach gauges dash"
The description states: "Chevy C50 big truck, around a 72 vintage"
Presumably, a C50 might have been equipped with either a 6 or an 8 cylinder engine. However the eBay listing states: "This was pulled from a Chevy C50 big truck, around a 72 vintage. The truck is long gone, this was pulled before it was crushed."
Too many unknowns?
Materman,
If it is indeed from a C50 truck, and if a C50 truck might have had either a 6 cylinder or 8 cylinder engine, you might want to steer clear of that tach?
OK, thanks guys! I'll keep looking
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
