2 members (porsche, Dennys28), 93 guests, and 2 robots.
Topics128,051
Posts1,055,766
#115329 12/14/2004 12:38 AM
I
Junior Member
Junior Member
I Offline
Hello,
I have been taking parts off one by one and sanding them to bare metal then repairing any defects then spraying with can sandable primerfor tmep protection untill I get them all done. Should I have used a primer sealer instead adn can I spray a sealer over the sandable primer?
Thanks, Ivor
63 chevy short/fleet 292/4speed
under construction
First, welcome to the Bolt. This is a great site and the info here is great. I noticed that you haven't filled out your profile so I don't know anything about you. You may want to do this so the folks here can know what you have and where you are from. :confused:
I'm a hobbiest when it comes to painting and I don't usually have parts off for any length of time before painting, but I would diffently give the parts a coat of sealer. You can get sealer in a can ready to shoot.
I live in So Cal cool so for me if I had the parts in the garage I wouldn't worry about it, but if you are in a wet part of the country, or you are leaving the parts outside, you got to seal them or they will rust.
Good luck! hope this helps. smile
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
