1 members (dt235sd), 307 guests, and 7 robots.
Topics128,159
Posts1,057,039
Members48,460
searching for a replacement wheel for the truck.Ideas?
Here's what the wheel looks like now.
1959 Chevy Viking 60 & Wrecker
See I told you it would work. That Beaver Cleaver will do anything.....
Are you looking for alternatives or an original replacement?
I have a set of 7 of the 18" wheels. Some of them should be OK.
https://www.dropbox.com/s/hjcgm29asy4rop4/100_3902.JPG?dl=0
1953 3800 Dually Flatbed
If this is a parts wanted ad please include more details and the proper place to post is in the swap meet section, not general forum.
If you're looking for ideas and suggestions first then this is the right place. Please also include more details of what you're trying to do and why, you'll get better answers if you ask clear questions.
•1952 Chevrolet 3800 pickup
---All pictures---
the one i have are 16' but those look just like some of them.all 3 piece i believe.I have a few bad ones original is awesome or whats a good replacement?
Many thanks Grigg I often think what to ask seldom type the same.
wheelsnowinc.com has replacement wheels for older trucks. You have to search by wheel size, then # of studs and bolt circle.
They offer a 18 x 8 8 stud on a 6.693 in bolt circle. They also stock 16 inch wheels
Our trucks use 8 lugs on 6.5" bolt circle.
If your truck had 18" originally and you'd like to go back to that you'll be looking for old/used wheels.
For a modern equivalent tubeless wheel and tire look for 19.5" wheels and 8R19.5 tires are a good option. This is what I have on my 1 ton.
You may also fit some 16" wheels, check clearance on rear brake drums. Depending on the tire size they may or may not be as tall as you want.
---All pictures---
Are the 55' 2nd series GMC 150 3/4 ton dually wheel size and offset similar to the 3600 or 3800 dually setup.
I am having issues figuring out the right offset to fit my truck.
The problem is the truck is (6) hours away and I cant retrieve it until I replace the stock wheels and tires which I will do on site prior to loading it up.
The manual states my size is 16x6-8lug on 6.5 but I swear it is a 15" wheel.
1955 GMC 150
3/4 ton dually flatbed "The Farmtruck"
3rd generation all original with 40k miles
Moderated by  Dusty53
