7 members (KEVINSKI, Southerntruck, 3800GUY, klhansen, dt235sd, Otto Skorzeny, Hotrod Lincoln), 66 guests, and 3 robots.
Topics128,079
Posts1,056,301
Members48,441
How much gap should there be at the bottom of cab and front fender?
Check video:
Here is a picture of the gap: (image)
U
U Offline
Hidiy mr_mahoney-
I watched your video & looked at the picture. I would loosely assemble the whole section, then do a shim/tighten/loosen-as-needed job with the whole front end. You may need that gap as it is; you may need it to close; it may need to widen.
Doors and hood need to open & close properly, then address that gap. And you mentioned what was "allowable" in the video. That is up to you. Where are you at in this process? Final assembly? Or do you want this as a test fit?
Brad
(edit- list the make & model in your subject next time so more people will know that you're asking about a '52 3100)
Wrench Fetcher, PhD
Thanks for your advice 👍. I am test fitting everything before paint.
Do most trucks have a gap down there at the bottom?
Ex Hall Monitor
Ex Hall Monitor
As a rule fit & finish weren't important in that era. You should see some of the gaps on my '38. eek
The first thing you need to do is align your hood properly. Do this while the fenders are down and out of the way.
An important factor in this process is that the fenders are adjusted to fit the hood, not visa versa.
Once your hood is aligned, you need to raise the rear of the fender to remove that gap. Looking at your pictures/video, you may need to make the holes larger so that the fender can come up far enough. I recommend completely removing the bolts attaching the inner fenders to the toeboard and parking brake bracket to aid in moving the fenders with less restriction. These can be easily replaced once you tighten up the fender-to-outer cowl bolts.
Carl
