| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Can someone confirm that the generators are the same on the 1946 GMC trucks as are the 1946 Chev. trucks? I just wanted to make sure whereas the GMC is Pos. ground and the Chev. is Neg. ground. My thinking is that it should make zero difference to the generator, the rotation is the same on both engines, output should be the same...etc...etc... I need a serviceable generator to replace my bad existing generator. | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | A generator can be polarized either way. The part numbers might not match up between Chevy and GMC, but as long as it's polarized properly the charging system should work OK. Not so for regulators- - - -most of them are polarity-specific. Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | According to Hollander they are the same. Also used on Chevy cars, Federal, International, Mack, Olds, Packard, Pontiac, Reo, Studebaker and White. | | |
