2 members (jay d, Gdads51), 75 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
#1152221 02/27/2016 12:02 AM
1954 chevy 3100 vent window just flops in the breeze when open. I suspect the top rivet controls that function. What can I do to tighten it up/ new rivet?
Thanks Steve
is there supposed to be a tension nut at the bottom of the wing assembly? my 53-53 have a large diameter spring, in which you adjust the nut to put more/less tension on the window, Check the factory assembly manual, or shop book. Mike
MIke is correct (I'll look for a photo in a manual - please post a link to an image, if you have one).
There is a set of parts inside the door on the lower, threaded, mounting post - they put appropriate tension on the wing/vent window.
I think someone has posted a photo of the parts needed to provide proper tension, without pulling the vent-glass frame downwards off the glass.
Great....thanks for the help. I now remember seeing that spring on a window. I hope the PO installed it.
TC Steve
If you don't have it, let me know. Mike
Moderated by  ndkid275, Phak1
