| | | Forums66 Topics128,091 Posts1,056,392 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I have a photo of the driver side of my firewall: www.photobucket.com/bobs46It should be the first photo in the list. The firewall has a large (10" x 10") "X" stamped in to the metal. Inside of this area are 4 holes that look like they have been used to mount something at some time in the past. Does anyone have any ideas what they might be for? Just to the right of these is a larger (1" dia?) hole that looks unused even in the pre-paint pictures. Again, any ideas? Bob
BobS46
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | The four little holes are non-original so they are of no consequence. The large hole is for the wiper vacuum hose. | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | When I got the truck, the wiper hose out in a hole in the upper right, where I now have it located. So, what originally came out of the upper right hole?
BobS46
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Hi Bob,I have photos in photobucket that will help. Your wiper hose is coming out the wishbone front end rod support. My oil filter was mounted to the fire wall so I just kept it there. | | |
