| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | 1954 chevy 3100 vent window just flops in the breeze when open. I suspect the top rivet controls that function. What can I do to tighten it up/ new rivet? Thanks Steve | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | is there supposed to be a tension nut at the bottom of the wing assembly? my 53-53 have a large diameter spring, in which you adjust the nut to put more/less tension on the window, Check the factory assembly manual, or shop book. Mike | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | MIke is correct (I'll look for a photo in a manual - please post a link to an image, if you have one).
There is a set of parts inside the door on the lower, threaded, mounting post - they put appropriate tension on the wing/vent window.
I think someone has posted a photo of the parts needed to provide proper tension, without pulling the vent-glass frame downwards off the glass.
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Great....thanks for the help. I now remember seeing that spring on a window. I hope the PO installed it. TC Steve | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | If you don't have it, let me know. Mike | | |
