| | | Forums66 Topics128,158 Posts1,057,023 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | When was the last year Chevy made the exact same 3-speed tranny I have in my 1950 1/2 ton? Swapmeet season is here and I'm looking for an exact replacement to keep as a backup. If Chevy came out with a newer tranny that's even better & would bolt up to my 216 I'd be interested in that also.
Thanks!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | SM-420's were made through '68, then SM-465's, either with short input(9" approx) will work. 465's aren't necessarily better, parts OK for both.
This is assuming you have an open driveline.
Ed
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 48-54 3 speed trans. are the same. The 55 up was a little stouter but they are built for open drive shaft. Like Pruss says you could use a 4 speed granny SM-420 but it will have to be from the same era because of the closed drive shaft. To use any other trans you would need to change the rear end & use an open drive shaft. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | So to be clear.......I need to look for one of the AD truck transmissions from 47-54. Anything newer would involve changing to an open driveshaft.
Thanks Ed and Wrenchbender!
Chuck
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 48-54 3 speed trans. are the same. . . So to be clear.......I need to look for one of the AD truck transmissions from 47-54. Anything newer would involve changing to an open driveshaft.
Chuck Almost correct. 1948-1954, as posted by Wrenchbender (1947 is a different length). Almost correct. 1954 1/2 ton only. The 3/4 and 1-ton 3-speed in 1954 were for fully open drive lines. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thanks Tim for even more clarification. I appreciate it.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Even though the 1954 3/4 and 1 ton 3 speed were open drive, they used the same transmission with a goofy rear bushing, seal and yoke adapted to the same transmission as the torque tube style.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Dave
I assume from (just now) re-reading in the 1954 manual, that no universal joint ball adjustment is needed on/with the 3/4 and 1 ton 3-speed truck?
I also see that the standard 3-speed transmission on the 1/2 and 3/4 ton 1954 trucks was not available on the 1-ton. A heavy duty 3-speed was available as an option on 1-ton trucks (4-speed was standard). Did that H-D 3-speed have the same rear "cover" as you described above? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, I was going by your post when saying "3/4 and 1 ton"(I did not look it up). I have a 3/4 ton example, but not a 1 ton.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Dave - I had never read/noticed that oddity.
Is there a chance you have one you could photograph? This is interesting.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | On the SM420(original 4 speed) transmission, you can use the "open" drive later with a torque tube. If you save the "tail" off of the older transmission. It bolts to the same pattern with out modification. The "ball" casting is bolted to the rear of the casing in the same place as the "seal" casting on the newer transmission. Same applies to use of the older SM420 in an "open" driveshaft. Just change the "ball" casting out for the "seal" casting and in it goes. I never, ever throw stuff out like this. Has saved me many times. You can use the 4 speed from 47 to early 60's if you need to. One part and all is good. I have not tried this with the 3 speed so no advise or opinion for that.
Steve H
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim, here you go, nine photos
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Those are great photos, Dave - THANKS
Steve, what you describe is good information (for 1948 and later SM420s). However, was the SM420 used on 1947 Chevrolet trucks? It looks like the SM-420 was introduced in 1947, but a spur-gear (no-synchromesh) transmission is listed in the 1947 Truck Specifications Manual. I think the torque-tube length and transmission lengths changed in 1948? I am not sure about this - just asking.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | I don't have a 47 to poke at. But the kind folks at Novak seem to think the 47-53 are the same(includes synchros?). The torque tube changes to open after 53? Here is a link to the "Information" part of the site: https://www.novak-adapt.com/knowledge/transmissions/manual/sm420 With out one to poke and mess with this is as good as I can do.
Steve H
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1/2 ton 1954 tucks still used a torque-tube (3.90 R&P vs 4.11 R&P in earlier years).
The SM420 front bearing retainer "snout" changed in 1954.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Some detail changes over the years. Loose bearings in the older versions. The snout as you said. The mounts, length and bolt patterns are the same. Some changes to the synchros, I think. But an old and a late will fit into the same place. The output shaft has the same spline count and the input as well(might be some "special" applications for non-GM applications) but over all you can use almost any year transmission in any year truck. Keep the tail casting that fits the application and off you go. The Jeep guys love the low stump gear for crawling. Was a good tough transmission.
Steve H
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | 1948 through 1954 use the same case with the same casting number. However in about 1952 they changed from a 2 lug to a 4 lug synchronizer, changed second gear and a few other things. You have to be careful when you rebuild one of these. The entire set of gears will move from one case to another, but you cannot mix and match other parts. The early and late is easily identifiable by pulling out the input shaft. If you expose a 2 lug synchro, you have the early model. If you expose a 4 lug synchro, you have the late model.
The HD transmission is a Borg Warner T89 which is very similar to what Ford used behind Y-Blocks and their FE engines.
The hardest part to find for the old 3 speeds is the synchro. At one time the brass rings were reproduced in the aftermarket. but the brass rings as well as the complete synchro is getting really hard to find. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Keep the tail casting that fits the application and off you go. The Jeep guys love the low stump gear for crawling. Was a good tough transmission. So you're saying, all the main transmission case lengths are the same. And the only thing that is different is the tail housing casting lengths? Isn't the main output shaft a different length when using a torque tube verses open drive shaft? | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Jorb: The difference in length from "Tube" to "open" is all in the tail housing and the yoke. The yoke went from a trunnion to modern needle bearings. And the modern yoke is much shorter. The late rear casting has a seal and big diameter hole to accommodate the "open" style yoke. The casting is much shorter so the drive shaft is longer than the shaft in the torque tube.The out put shaft is the same. The case is the same. The output yoke changes and the rear housing. That is about it. Inside the case is as has been posted. Lots of changes over the years. Shaft splines, and length however stayed the same.
Steve H
| | | | | Joined: May 2011 Posts: 18 New Guy | | New Guy Joined: May 2011 Posts: 18 | Wrenchbender wrote "The 48-54 3 speed trans. are the same." My 51 Chev. 3100 3 speed is jumping out of gear at speed and sometimes hard to get in 1st and 3rd. Have a 54 trans. with engine standing by although no idea of internal condition. Questions...any idea what is causing the issue? will that 54 attached to a 235 cu. in. bolt up to my 216.5 cu. in. or will modifications be necessary? I suppose by Wrenchbender comments the parts are interchangeable (as in tear down the 54 for parts)? If I need to go elsewhere for parts, any suggestions as to who may have serviceable parts? Thanks, TexChev | | |
