8 members (Robert Crandall, kades51, Hotrod Lincoln, jay d, Hanks custodian, Rusty Heaps, Uncles51, 1 invisible),
124
Mod | | | Forums66 Topics128,041 Posts1,055,480 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I continue to chip away at the single running boards on my 1 ton. (1950) I had to splice two good pieces together and I am looking for tips and suggestions on how to planish the welds in those very tight little ribs on the board. Has anyone done this? It looks good tacked together for now, but I don't want people to be able to tell that it is two pieces. Thanks.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I ground those welds down with 60 & 80 grit die grinder disks and planished with a piece of 3/8" steel plate on edge in the vice to get at those small seams.
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | This has nothing to do with planishing but I had to do some really serious patching in a section of one of my running boards. I didn't have a lot of issues with distortion because they are made of somewhat heavy material. they turned out really well but had some slight imperfections, to hide these and create some durability I sprayed them with a good bedliner material. I also did this because I didn't want to deal with scratching black paint during use. This is one of the few things on my 41 that is not stock but it looks great! | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Fox: I had to section my running boards also and had a seam that I just could not get cleaned up to my satisfaction, so like Wanderwilly I went the Line-X route. After the the Line-x was applied I realized I didn't have to get the body work on that spot cleaned up as much as I did as that Line-x hides small mistakes. You'd never be able to tell that I took about 18" out of the running board in this spot. Line-X hides imperfections And that stuff is tough as nails. Regards, Dave | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Wow. That Line X looks really sharp! I'm going flat black on the 1 ton and that would blend very nicely. You've swayed me...LineX it is! | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Fox, you won't regret covering that running board with the Line-X and it will look really sweet with a flat black truck. Did you check out my Line-X'd steering wheel in my Gallery Story? That turned out pretty cool, too..... Dave | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | Linex on the steering wheel is a dynamite idea.  I was planning on using it on my running boards from the start, but haven't tackled them yet. That's what I used on the Lund fiberglass running boards I put on my SuperDuty instead of the cheesy stick-on treads they came with.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Thanks for the thumbs up, kl! | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | For any planishing like those on a running board, I like to find a piece of steel bar stock the same width as the underside detail between the bends. Less chance of adding any errant marks..... | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | A few more questions for you Dave: 1. For the LineX'ed steering wheel, how big of cracks could the LineX cover. I quite like that look too. Tough, simple, "original"...ish. It looks great! 2. How much did it cost to have the boards, apron and wheel done in LineX? 3. Also, what kind of bench seat did you use in your truck? It seems to fit very nicely. Thanks!
| | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | Fox; 1. The cracks in my wheel were at most maybe 1/16" although the line-x guy said it would bridge 1/8". I'd probably fill an 1/8" crack before I'd let them have it tho. They'll do other than black but it's 2x more than black. Upon their suggestion that it holds paint well I just hit mine with a can of grey Rustoleum. It's holding up great! And mask off any area you don't want coated. It's a 2 part material and cures in 4 seconds. 2. The boards were $270, both sides. The aprons were $70, both sides. The wheel was $40. 3. The seat I lucked out on years ago. It was the third seat out of a mid 90's Windstar van. It was a take-out and still had the plastic on it. $50. The guy had 6 of them in different colors. The bottom cushion was a bit too soft so I cut out a piece of 1/4" Masonite and slid that between the bottom coils and the foam above it. Nice and firm now. I put power on it, from a 1992 Park Avenue. (Took the tank out of the cab first). Fox....good luck w your project! Regards, Dave | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | |
