| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | looking to add power steering to my 54 3100. my question is, does anyone know if an ELECTRIC POWER STEERING unit will work. I have a double pulley harmonic balancer, but also want to run an AC unit. looking to run a IFS front suspension, so if I can use EPS then I could get a manual IFS. thanks in advance. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Yes, electric power steering can be used and another option is to use an electro/hydraulic pump. Toyota MR2 is one source as is some models of Kia. It plumbs in with hoses just like a belt driven one.
Evan
| | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | There has been a lot of discussion on the interweb about this. One is here Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | thanks for the responses, I did see those pages when I did a search. what I haven't seen is where someone has installed either the unisteer or the vue box on an AD truck. you can get the vue box and controller on ebay for around 200, i'm sure the unisteer is going to be high dollar. thanks again | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | You're talking about something very custom so there's little chance you find someone who has done exactly what you want to do. Might have to blaze the trail here. | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | I've just completed the exact modification that you are referring for the same reasons on my '52. I used 2001 Saturn Vue parts I obtained on Ebay and it works great. I used the EPS to drive the stock steering box but if you are going to go with IFS the install would actually be easier. Be prepared to do a litte fabricating and spending a little time behind the lathe and mill. Send me your email address and I can send pics. | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | I've just completed the exact modification that you are referring for the same reasons on my '52. I used 2001 Saturn Vue parts I obtained on Ebay and it works great. I used the EPS to drive the stock steering box but if you are going to go with IFS the install would actually be easier. Be prepared to do a litte fabricating and spending a little time behind the lathe and mill. Send me your email address and I can send pics. thanks davealden, getting up there in age and need some modern comforts in my beloved 54 AD, she will be a cadilac 261, air con, IFS suspension, 55.1 rear end with 3.36 gears, 2 link rear suspension and power windows and will keep it stock looking. the only thing where i'm second guessing myself is the s10 t-5 over a auomatic trans. thanks again for the pix | | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | Just did the same electric steering install in my 50 3100 .. Used from a 2004 Saturn Vue and a controller from e bay Probably less than 200 to complete .. I am very impressed with the results and only took a couple days in my garage.. good luck with it Fred | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | Just did the same electric steering install in my 50 3100 .. Used from a 2004 Saturn Vue and a controller from e bay Probably less than 200 to complete .. I am very impressed with the results and only took a couple days in my garage.. good luck with it Fred thanks bro, got some pics from davealden, real nice setup. picked one up on ebay and also got the controller. my email is in my profile,sure like to see your setup. | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | Do you have some pics to share on your installation Fast Freddy and davealden? | | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | This is tempting me to abondon my plan of the Toyota push-pull PS box, due to having to sort out the pitman arm issues.
Looks promising, as long as the junkyard stuff is used. Looked up some universal kits at over a grand!
Larry W.
1953 3800 Dually Flatbed
| | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | wrench fetcher.... sent you some pictures .. hope you got them Fred | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | davealden and Fast Fredy, What did you use to couple the splined shafts to your steering shaft? I've found some steering U-joints on the internet but none of them seem to match the diameters of the shaft on the equinox eps. I measured .720 dia with spline count of around 36 on one end and .650 dia with a spline count of around 24 on the other end. The spline counts may be off, I didn't bother to do a careful count since I couldn't find U-joints of the matching diameters. Maybe I just need to buy 3/4" D-D joints and make them fit (and weld them). Any suggestions? Thanks.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | My Vue set up came with a splined U joint on the output shaft that was 3/4 inch same as the original steering shaft .. I just found / made a suitable length of thick wall tubing that would slip over each end and drilled and thru bolted it my email is [email protected] ... send me an email if you would like some photos .. Fred | | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | The key is getting the mating splined outer sleeves when you purchase your EPS. I used, or modified, almost every part of the EPS I purchased including the firewall seal. You can certainly modify the splined shaft to accept a double D joint but you wouldn't want a u-joint on the input side (steering wheel side) of the EPS, you just want to "hard-connect" it to your existing steering shaft unless you are going to configure some sort of tilt wheel arrangement. On the output side of the EPS you do want a u-joint and where and how you attach it will depend on if you are going to connect it to the existing steering box, like I did, or if you'll be connecting it to an IFS rack and pinion. I don't think the EPS units are designed for a lot of load pushing and pulling thru their length, the splines are there for crash protection (collapsible columns)and for assembly so you may want to take that into consideration if you aren't planning on using the splines. Send me your e-mail address and I'll send you pics of how I went about it.
Dave
