6 members (Donf, Eisenholtz, TUTS 59, Hotrod Lincoln, rfs56trk, 1 invisible), 58 guests, and 2 robots.
Topics128,203
Posts1,057,412
Members48,471
Hi All,
I am the proud owner of a 1955 C3100 ½ ton I bought a few weeks ago and the warm weather for February has me thinking about getting it ready for the driving season which may begin a little early here in Michigan this year.
Anyways, the truck I bought appears to have a low mileage 235 inline 6 ( correct year) and the odometer, if I believe the seller was reset at engine rebuild shows 300 miles. I will be driving it only in good weather for trips under 100 miles and probably only put a few thousand miles on it per year. My first questions are on fluids and some brake questions. I have read all I can find on the site so far, but still have some base questions I could use some experience. The truck is a mostly OEM 235, 3 on the tree, stock one barrel carb and oil bath air filter and has the optional oil filter for that year.
While it may be low mileage, I believe it has been at least 5 years since it was rebuilt, and if this is true, it might have spent more time sitting than running if that matters to any of the answers below. Of course the alternative is that the odometer rolled over smile
So here are my first set of questions
1) What grade of engine oil do you guys think would work well? — it looks like the manual I have recommends either straight 30 or straight 20 weight, but that recommendation is 61 years old and oil technology has changed — I have found straight 30 weight in several places so I can go that route easily
2) What grade engine oil for the oil bath? — Manual says 90 weight I believe — just wondering if anyone thinks otherwise
3) I have found more than one style of oil filter canisters that list for my engine. I can certainly measure what I have, but I was wondering if anyone had some thoughts on if the thinner diameter is better/worse than the larger diameter one ( May be only one fits anyways — I have not pulled the existing one out yet)
4) What grease are you using on the fittings? — By this I am wondering if I should go with traditional petroleum based grease, or a newer synthetic? - I suspect a traditional type is in my front end
5) I am reading that the U-joints also need lubrication — what is recommended here — I can’t find much info here other than the manual saying stay away from “soap” type lubricants
6) I am going to check the tranny and rear end levels, and go with the manual here — looks like a stick your finger in the hole and it should get wet kind of check to me — suggestions?
7) The coolant looks good, although I no longer own a hydrometer ( or what ever its called ) — any special instructions in case I Decide to flush and refill? — I will test it after I borrow the correct tool and change if necessary
8) the last owner said he ran premium in it, but this confuses me a bit as I don't think the compression is even 8:1 in this motor - my bigger concern here is that he was not sure if the valve seats were hardened. so a two for one question here. What gas is everyone running and is anyone adding lead additive to keep the valve seats happy?
I have lots more questions, but this is a good start and I appreciate everyones help. Here is a link to my baby below
http://i157.photobucket.com/albums/t49/JoeStine/IMG_0676_zps79vixssw.jpg
She is starting to talk to me and let me know she is sick of sitting in the garage
Joe Finkelstine
Born and bred in Motown
I'll try to answer these for you.
1; Any good grade of 10w-30 will be fine. There are some who will say you need to use "special" oil for older engines due to the lower ZDDP levels in modern oils, but that really doesn't apply to stock engines that are broken in. That said, however, if you are concerned about the ZDDP levels, and want something that has a higher amount, Valvoline and Valvoline VR-1 have the highest amount (I use VR-1 in mine).
2; Go with what the shop manual says to use.
3: I really can't help you much on this one, as I am running a different filter unit on mine. However, I do know that the cartiges for the Fram version are readily available. If the decals are still legible on the canister, it should tell you which filter it takes, and you can cross reference from there. some may look different, but fitment shouldn't be an issue.
4: Any modern chassis lubricant will be fine, either regular or synthetic.
5: same as 4, just make sure that it is a semi fluid grease.
6:Agine, go with the manual. You will have to be specific when you get the lube, as many modern "gear lubes" are not the correct spec for the older transmission. You want to stay away from GL-5.
7; Again, modern coolants will be fine, the "mix with any" type is the one you want. Do not use Dex-Cool (pink in color). A 50-50 mix is best. It is also available in a premix if you do not want to mix it youself, but it is a little more expensive.
8; Premium in these engines would be wasting money, and is not necessary. Regular 87 octane will be fine. Unless you're going to work the engine hard, a lead substitute reall isn't necessary, and if the engine has been rebuilt, there's a good chance it has hardened seat installed.
Bill Burmeister
U
U Offline
I use 100% Gasoline (non-ethanol) in my truck. Good answers above from Bill. As he mentions in several replies, the shop manual answers most questions.
The more you drive the truck, the better.
Brad
Wrench Fetcher, PhD
