2 members (cmayna, Wickedbass),
71
Mod | | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I'm contemplating a '48 235 rebuild . What max overbore is normal for this engine . Thanks for your time  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0624.htmShop Manual says 0.040" oversize, but, I have seen people post that larger pistons are available and can be used. Someone will correct/confirm a max practical/available oversize. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks Tim , that's what I was looking for . | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | I'm no expert by any means, but I have a 1955 235 bored .060" over. I found .080" pistons when looking to rebuild it and read about some.100" pistons being put in high performance applications, hut no one actually carried them. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | 1/2" over is perfectly safe, everyone says so. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have a 1961 261 that was .060 overbored in 1972 (my second engine rebuild).
It has been back in my Suburban for about 10 years. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Millions of stovebolt engines have run for decades with .060" and .080" overbores. When boring a block for a sleeve, it's common to bore the cylinder 3/16"(0.1875") or 1/4"(0.250") oversize without hitting water, but an overbore that size would not be suitable to run a piston in. I have sleeved hundreds of cylinders without any issues, so it's possible to salvage a worn or damaged block as long as there are no cracks or holes in the cylinder wall in the top or bottom 1/2" to 3/4" of the cylinder. Jerry
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Millions of stovebolt engines have run for decades with .060" and .080" overbores. Mine's one of them (.080"). I will confess that before the rings seated it ran hot enough to make me nervous but settled down after break in.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2009 Posts: 13 New Guy | | New Guy Joined: Sep 2009 Posts: 13 | Just following up on this topic. I was talking to the machinist that is boring my 235. It is currently at .030 over and now he doesn't think that it will clean up at .040 over so it would have to go up to .060. Has anyone noticed a power loss due to boring it that much? Would I get more power out of it by putting sleeves in it? I plan on running a cam from Patrick's in it with dual exhaust, 2 carbs, and HEI ignition.
1954 Chevy 3100
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | You will be fine at 60. I would even go .080 if need be but not more then that. But at .060 you can find pistons and rings so good to go.
Mike
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | You will actually gain a little power at 60 over, due to slightly more displacement and more compression pressure, but it would take a skilled dyno operator and a fair amount of luck to actually measure it. Be sure your cooling system is up to dissipating the extra heat load the thinner cylinder walls will create. Installing a new water pump and a new or rebuilt radiator would be a really good idea. Jerry
| | | | | Joined: Sep 2009 Posts: 13 New Guy | | New Guy Joined: Sep 2009 Posts: 13 | Thanks I feel a little more comfortable going with 60 now If it needs it.
1954 Chevy 3100
