4 members (UtahYork, 3B, dt235sd, Shardean), 118 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#1150603 02/17/2016 5:07 AM
Working on installing new glass and weatherstripping on a 1950 Chevy 1/2 ton. Single glass, pull down outside door handle...
Installing the new weatherstripping channel for the glass I see that the door is missing a channel inside for the weatherstripping to fit into.
The driver side door had this channel in it, but the passenger side does not.
I see where the channel is available for 1951 - 1955 1st but not for 47-50.
Any idea where I might find this missing piece?
Can I adapt the later model channel to fit the door so something holds the padded weatherstripping in place?
Roy Rodgers #1150638 02/17/2016 2:59 PM
It is common for this to occur on the front channel holder, the channel on the rear of the door is replaceable but not reproduced as far as I know.
Rear Channels
You can cut the rear to fit the front and then you need to spot weld or J-B weld it in place, the front is welded in place from the factory. You can find these channels used and NOS on eBay or you can place an ad in the Swap Meet section, (right or left) will work for the repair. This is not a simple fix the door needs to be stripped and most likely off the truck to work a lasting front replacement.
Inside of Door
The 1951-55 version as shown is completely different.
1951-1955 Version
Roy Rodgers #1150639 02/17/2016 3:02 PM
The front channel is still in place, just the rear (as you show in the picture) is missing.
Roy Rodgers #1150642 02/17/2016 3:11 PM
Roy Rodgers #1150648 02/17/2016 4:05 PM
Thanks DADS50. That be the piece I need.
Roy Rodgers #1150751 02/18/2016 3:42 AM
Dig deep into bottom of the door through the inside hole. I found mine in there.
Carl
Roy Rodgers #1150757 02/18/2016 4:10 AM
It was no where in the door. First place I looked. But an old friend of mine still has a 50 Chevy truck cab with the doors. It happened to still have the piece inside I needed. I'm lucky the family of the man hasn't hauled it away yet as scrap, but I took a chance and it was still there.
