7 members (52Carl, Robert Crandall, 1955 1 Series, Tinker5, Leo, Mike B, 1 invisible),
146
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,863 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | I've got a fenton dual carb set up on my '56 235 without carbs. I'm looking to purchase 2 single barrels and from what I've read here is that Carter YF's work the best. Does anyone have any suggestions as to whom to buy them from or where?
Thank you | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Take a look at this site. Harold http://thecarburetorshop.com/
Harold Is a restoration ever finished? | | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | I am using two W-1 Carters, they work great for my 250 engine. What ever you decide to use, they must be identical in number and metering. Don't assume over the counter replacements are the same, they are some of the worst carbs to use since the rebuilders use any part that fits. Pick up cores for cheap and rebuild them, that way you know what you have. Also, run them together, don't try progressive linkage, one end of the engine will always run lean if you do. My W-1s are small by them self, but together make the perfect size for a 250 ci.
Joe | | | | | Joined: Jun 2015 Posts: 149 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 149 | Harold & Joe
Thanks for the use full information. I'll do some looking for W-1 Carters and give the "CarburetorShop" a call.
Jeff | | |
