1 members (41 chev),
120
Mod | | | Forums66 Topics128,275 Posts1,058,572 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Gentlemen,
I am replacing my gas tank on my 1950 3600 truck. The old straps were basically rusted off, so I just used some tin cutters to release the gas tank. Now I have the gas tank out and am ready to put the new one in with new straps. I'm drawing a blank as to how to remove the old straps. Are they welded to the floor of the cab and the rear of the seat frame part that's welded to the floor? I tried prying them with a screwdriver and it wasn't budging. The new straps look like they would be more likely to bolt in, or else they just slide in place. Can anyone solve this riddle so I can get this finished up and put the new tank in? Thanks!
1950 Chevy 3600 w/ 54 235 motor
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | There is a pin with a hole in the end of it for a cotter pin.
| | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | There is a pin with a hole in the end of it for a cotter pin. OK wonderful, thank you. Do you by chance recall where this might be? I looked on the new one and didn't see this, I guess they expect you to reuse the old cotter pin.
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | The attachment of the tank strap at the cab floor is directly behind the seat base. Get a flash light and a mirror and you will see the pins held in place by cotter pins.
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I have not replaced these straps! It appears from your pictures that the brackets may be riveted or spot welded to the floor where the holes in the new brackets are. If you clean up those areas on the old brackets you may be able to determine the mounting method used.
Ed
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Those brackets are spot welded in several spots. Clean all of the crud out of the way and look for low spots indicating the location of the spot welds and start grinding away. Carl
| | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Well, with as tight as they are in there, I think I am just going to remove the straps from the new ones and install them where the old ones went. Now I just need to work out how to get the bolts out. Unfortunately they didn't use something simple like a cotter pin, instead there is some black plastic washer looking thing holding the bolt in place. I tried knocking it out with a hammer to no avail, tried using a screwdriver to snap the plastic washer, still to no avail. I hate damaging new parts but this thing is about to get some Dremel action done on it if I can't work out how to get the bolts out!
