10 members (Tronman, Wayne67vert, Shade Baby, Pre '68 Dave, klhansen, Wally / Montana, David Bush, 1955 1 Series, Hotrod Lincoln, Gray_Ghost),
88
Mod | | | Forums66 Topics128,051 Posts1,055,714 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | On these after market tail lights it has a black and green wire which is the tail lights and which is the stop lights ? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If the bulbs are the same it dosent matter
Choose the same position
Example. Lower bulb tail, upper brake/stop | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Ok Thxs . That's how I installed just wasn't sure . Both bulbs are the same | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If this is the type you have ...pic... I think you will be disappointed with the results. | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Yes those are exactly what i have .. Why well I be disappointed ? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Not very bright
The brake/stop in no brighter than the tail
If I remember correctly one is mounted upside down opposite from the other side.
| | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Exactly what have there is basically two bulbs in the housing which is the tail light then the other for stop light . So how do u fix this problem ? | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I bought a set of trailer lights and removed the "innards" and fitted them into the stock housings. So I had running lights, brake lights and turn signals. the trailer light parts were quite a bit heavier than the stock replacements.
| | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Read my reply to your other thread on the same subject.
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | sorry no pics... I bought stock type lights and was not happy with the flimsey inside parts. the trailer lights are typical of those found in any auto parts store.
